Jump to content
Electronics-Lab.com Community
Help needed desperately with DS2711 - NiMH Batt.Charger IC !
Gromit
Hi everybody, and Merry Christmas!
Has anyone made ​​a battery charger with DS2711 chip? If so, please, tell me:
1) I intend to make a parallel circuit as in page#7 of datasheet (see attachment) - what transistors can I use instead of FCX718 - I prefer non-SMD transistors that can handle, say, 1Amp of current (2-3 A even better)?
2) Can I use other type of thermistors, like <http://www.futurlec.com/Thermistors.shtml> from futurlec.com (with same 10kOhm value, of course)?
3) What to do with "ICHG" and "IFB"? I assume that ICHG is for connecting power for charging batteries - is 5V sufficient (for 2 bat. in parallel)? IFB is tied to CSOUT pin of IC - how can I use it? Can it stay "floating"? As it is "Current Sense Output" maybe this pin outputs some feedback voltage that can be processed with some MPU or so?
4) Can I use wirewound sense resistor and what power should it have?
Thanks in advance!
ExtractPage1.pdf
Link to comment
Share on other sites
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
