Guest adrian1472 Posted February 10, 2012 Report Share Posted February 10, 2012 Hello,I followed the instructions on the site about recelling a lithium ion battery pack but unfortunately it didn't work out quite right.I have a 6 cell battery pack from my gateway which I recelled when I put the battery back in the laptop it ran the laptop but it wouldn't charge when I plugged it in. So I ran it down hoping that it may charge once the voltage dropped, I was wrong. I don't really know where to go from here. Here is some of the info from about the battery that may be helpful.adrian8@gateway-ubuntu-sda8:~$ cat /proc/acpi/battery/BAT0/infopresent: yesdesign capacity: 57720 mWhlast full capacity: 11888 mWhbattery technology: rechargeabledesign voltage: 11100 mVdesign capacity warning: 3996 mWhdesign capacity low: 0 mWhcycle count: 0capacity granularity 1: 355 mWhcapacity granularity 2: 355 mWhmodel number: W35052LBserial number: 111005200 battery type: 4C 69 00 00 00OEM info: Gatewayadrian8@gateway-ubuntu-sda8:~$ cat /proc/acpi/battery/BAT0/statepresent: yescapacity state: okcharging state: chargingpresent rate: 0 mWremaining capacity: 1 mWhpresent voltage: 10974 mVadrian8@gateway-ubuntu-sda8:~$ acpi -VBattery 0: Charging, 0%, charging at zero rate - will never fully charge.Battery 0: design capacity 5259 mAh, last full capacity 1083 mAh = 20%Adapter 0: on-lineThermal 0: ok, 52.0 degrees CThermal 0: trip point 0 switches to mode critical at temperature 100.0 degrees CCooling 0: LCD 0 of 7Cooling 1: Processor 0 of 10Cooling 2: Processor 0 of 10Thank in advance for any help. Quote Link to comment Share on other sites More sharing options...
Hero999 Posted February 10, 2012 Report Share Posted February 10, 2012 A safety feature of battery management systems is to refuse to charge the battery again once the voltage has dropped below a certain level. The only way round it is to reset the battery management system. Quote Link to comment Share on other sites More sharing options...
Guest adrian1472 Posted February 10, 2012 Report Share Posted February 10, 2012 Thanks for the reply, I wish I knew this before I would of soldered a set of cells to the board before replacing the old cells. I guess you have to make mistakes to learn. How could you reset the battery management system? Quote Link to comment Share on other sites More sharing options...
