Why caps in paralell?
walid
Another reason for using many capacitors in parallel is it gives lower impedance to higher frequencies if they're spread across the PCB traces.
I understand from your words that if I had two caps, one of them is equal to 5p and the second = 10p.
Better to use the two in parallel to get 15p and not one 15p to make an easy path for the high-frequencies toward ground???
