Jump to content
Electronics-Lab.com Community
Common Emitter Audio Amplifier Question
I'm tring to build an audio amplifier. I decided to use a basic common emitter amplifier circuit as a starting point and added a speaker to it.
I have some questions about the circuit.
1-) Is 2n2222 ok for this circuit?
Results of DC analysis: Vce = 10.06V and Ic = 1.26mA (I guess, these values will be used for choosing the transistor.)
2-) What's the output voltage of a standart mp3 player? Can it be 300mVp as I read somewhere?
3-) When I assume ß = 150 and input = 300mVp , the output is -2,13Vp . I guess it gives 1w power to speaker. Is there something wrong?
4-) Is connecting speaker parellel to output R ok?
Thank you..
Link to comment
Share on other sites
  • 4 months later...
for building the audio amplifier u need to use a power BJT class b push pull mode for obtaining good amplification.
No.
A class-B amplifier produces horrible crossover distortion. Audio amplifiers use a class-AB output stage.
I simulated the circuit with an input of 1V peak.
With a 12k ohm load the output is pretty good (almost 5V peak).
But the 4 ohm speaker seriously overloads the simple circuit and reduces the output to almost nothing (4mV peak).
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
