Jump to content
Electronics-Lab.com Community
5V Inductive Charger Design
pmitch
I need to design a 5V inductive charging system.
I will be using a 12V DC input voltage and require a 5V DC (500ma or more) voltage output.
Does anyone have any ideas where I can start? I need to build this from the ground up and need to start with my electronic schematic designs and then protoype and test.
Thanks in advance.
Link to comment
Share on other sites
  • 2 weeks later...
A 5v charging system, I'll guess to charge a 5v battery, will include resistors and capacitors too. The idea is to start with a higher voltage and a regulate the ouput at 5v. Automobile battery chargers are suited for general auto battery charging, while others are designed to charge less durable, higher technology small capacity batteries. What's the capacity or Amp/hr rating of the battery?
Link to comment
  • 5 weeks later...
  • 2 weeks later...
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
