andyh 0 Posted January 12, 2013 Report Share Posted January 12, 2013 Hi people my name is Andy and my knowledge of electronics is extremely limited i don't even know if this is the right place to ask the question I collect miners lamps and have several from the 1950's/1960's that need an electronic ignition .The ignition was applied in the lamp room at the collieries what i need to know is if it is possible to make a device that is 4.4 volts and 25ah output ?this device works by applying two wires to the lamp one to an isolated ring and the other to the lamp the current then passes through a platinum wire above the wick which glows and lights the flameany help would be appreciated thanks in advance andy Quote Link to post Share on other sites
Hero999 5 Posted January 12, 2013 Report Share Posted January 12, 2013 Ah is a unit of charge, normally used with reference to batteries, not current.It sounds like you need a 25Ah 4V lead acid battery. It will be very heavy though, 3.4kg (7 1/2lb) according to the data sheets I could find for batteries of this size. 4V is not a common voltage though. You may need to make if from two 2V cells. Quote Link to post Share on other sites
andyh 0 Posted January 15, 2013 Author Report Share Posted January 15, 2013 Ah is a unit of charge, normally used with reference to batteries, not current.It sounds like you need a 25Ah 4V lead acid battery. It will be very heavy though, 3.4kg (7 1/2lb) according to the data sheets I could find for batteries of this size. 4V is not a common voltage though. You may need to make if from two 2V cells.Thanks for that Andy Quote Link to post Share on other sites
andyh 0 Posted January 17, 2013 Author Report Share Posted January 17, 2013 Just a thought ! Could i make a device from say a 6 or 12 volt battery and transform it down ?Andy Quote Link to post Share on other sites
Hero999 5 Posted January 17, 2013 Report Share Posted January 17, 2013 Yes but the battery would need to be larger to get the same battery life because it would need to store more energy to make up for what s lost in the converter.25Ah sounds much larger than necessary. Have you simply tried connecting three AA NiMH cells in series to give 3.6V to 4.5V? If that doesn't work, try using C cells and make sure they're real 4000mAh or 4500mAh cells, not just normall AA cells with extra padding. Quote Link to post Share on other sites
andyh 0 Posted January 17, 2013 Author Report Share Posted January 17, 2013 Yes but the battery would need to be larger to get the same battery life because it would need to store more energy to make up for what s lost in the converter.25Ah sounds much larger than necessary. Have you simply tried connecting three AA NiMH cells in series to give 3.6V to 4.5V? If that doesn't work, try using C cells and make sure they're real 4000mAh or 4500mAh cells, not just normall AA cells with extra padding. Hi , I haven't tried anything yet as i needed information on the best way to do it this is a video clip off Youtube but the guy doesn't explain exactly what and how he came up with it I hope this posts thanks andy Quote Link to post Share on other sites
