Guest mommylicious Posted May 6, 2013 Report Share Posted May 6, 2013 Hello,I don't know how can get my computer IP number. please suggest me.Thanks Quote Link to comment Share on other sites More sharing options...
Guest eleven Posted June 5, 2013 Report Share Posted June 5, 2013 Every device connected to the public Internet is assigned a unique number known as an Internet Protocol (IP) addressOpen the control panel, open Network Connections, right-click the "Local Area Connection" (unless you've renamed it to something else) and chose "Properties", then (in the "general" tab) select "Internet Protocol(TCP/IP)" and click the "Properties" button. Check the "Use the Following IP address" checkbox and enter your desired IP address. Quote Link to comment Share on other sites More sharing options...
Guest garyson Posted June 5, 2013 Report Share Posted June 5, 2013 Follow my Easy steps:1) Open Command Prompt.2) Type "ipconfig"It will show the IP address of your PC. Quote Link to comment Share on other sites More sharing options...
Guest remonx6 Posted August 1, 2013 Report Share Posted August 1, 2013 ok follow me.Open Control panel >>network and sharing center>>Click on connection >>click on detail. there have ip and config detail.Thanks also u can use online system. search in google about ur ip, then after calculation they will showed ur ip by online system.Thanks Author Quote Link to comment Share on other sites More sharing options...
Guest remonx6 Posted August 9, 2013 Report Share Posted August 9, 2013 or if u want to check ur ip then use speedtest.net website. thanksEng remon Quote Link to comment Share on other sites More sharing options...
