Guest kellynicerf Posted October 26, 2013 Report Share Posted October 26, 2013 RF4463PRO module adopts Silicon Lab Si4463 RF chip, which is a highly integrated wireless ISM band transceiver chip. Extremely high receive sensitivity (-121 dBm) and +20 dBm output power ensure that the covering of the range and improve the data link performance. Built-in antenna diversity and the hopping function can be used to aggressively improve the performance. here is its basic information:Working voltage: 1.8-3.6VWorking frequency: 433/470/868/915 MHzOutput power: -5~20dBm (2000m distance)Modulation mode: (G)FSK/4(G)FSK/(G)MSK/OOK/ASKSleep current: <0.1uAReceiving current: 10.7~13.5mATransmitting current: 850mA@20dBmSensitivity: -126dBmRF data rate: 0.123~1000KbpsFeatures:*FrenquencyRange:433/470/868/915(Customizable 142-1050MHZ)*Sensitivity up to -126dBm *Maximum output power:20dBm *10mA@receiver status*Data transfer rate:0.1-1000kbps *(G)FSK, 4(G)FSK, (G)MSK OOK and ASK modulation mode*1.8-3.6 V power supply *Ultra-low consumption shutdown mode *Digital received signal strength indicator(RSSI) *Timed wake-up function*Antenna automatic matching and bi-direction switch control *Configurable packet structure *Preamable detection *64/128 bytes transmit and receive data register (FIFO) *Low power detection*Temperature sensor and 8 bits analog-to-digital converters *Working temperature range:-40 ~ +85°C *Integrated voltage regulator*Frequency hopping *Power-on reset function*Puilt-in crystal adjustment function for detail or loading down its datasheet, please visit: http://www.nicerf.com/product_view.aspx?id=21or our Aliexpress store: http://www.aliexpress.com/store/934254 Quote Link to comment Share on other sites More sharing options...
