Jump to content
Electronics-Lab.com Community
Job/Project Offer: Automotive Application
Guest VlaDeMaN
Guest VlaDeMaN
hi everyone,
i'm in a bit of a time bind and i need help building a box to remedy a problem i have with my car. I only have until march 14th.
Fuel Level reads 0-50ohm (empty to full) for a 12V fuel gauge.
Motor was swapped and new car computer (ECU) needs to read fuel level as well, but it needs 50-250ohm over 5V signal.
i need to split fuel level sender into 2 outputs: #1 for the fuel gauge, as the sensor reads it, and #2 for the ECU, as a ratio of the sensor resistance, unless you have a better idea.
i can put it all together but I need the design and programming. i already have an arduino which i think could be helpful, but not sure what else I will need.
let me know your $ requirement, thanks!
Link to comment
Share on other sites
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
