Jump to content
Electronics-Lab.com Community
Flyback Primary Current Problem
Guest eemree87
Guest eemree87
Hi Everybody, I implemented a flyback converter, but while I am expecting a triangle shape current at primary side (in DCM) and a square wave current shape in CCM I measured sth like sinusoidal. I couldn’t get rid of it for one week. I need your suggestions and comments. Thanks .
I explained the problem in details here:
http://www.docdroid.net/a09f/flayback-primary-current-problem.pdf.html
Link to comment
Share on other sites
  • 2 months later...
Where is the schematic? What is the output voltage & current? Where are you measuring the input current... directly across the I sense resistor? Do you have a RC fiter on it before the PWM
Try to make it run without the active clamp first (just use RC or DRC snubbers).
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
