Guest bhuvaneshnick Posted April 13, 2014 Report Share Posted April 13, 2014 what is difference between volt per second and volt-second Quote Link to comment Share on other sites More sharing options...
Guest swarner11 Posted June 25, 2014 Report Share Posted June 25, 2014 I think:Volts per second = V/T , volt seconds = V X T. Volts per second is a rate of change, so if a points changes from 3 V to 10 V in .03 seconds, the rate of change = (10 - 3 )V X 1/.03 = ~210 V/seconds. This rate of change is important as it governs the amount of current passing through capacitors.To work out the volt seconds using the same figures. 3 V + 7/2 = 6.5 V (average voltage) X .03 =~ .195 VS. I have never seen this unit used in electronics. Thanks Quote Link to comment Share on other sites More sharing options...
Guest bhuvaneshnick Posted June 26, 2014 Report Share Posted June 26, 2014 u might have seen that in battery 5vsec or 5Kwsec Quote Link to comment Share on other sites More sharing options...
