Jump to content
Electronics-Lab.com Community
schottky specification in LCD monitor switchmode supply
mcbmcb0
Hello
I'm fixing a 19" monitor switchmode supply which has a shorted schottky diode, type SB5150. That's a hard part to find where I live, so I'm wondering about replacements.
SB5150 is a Schottkey Barrier diode rated 5Amp and 150V reverse voltage. But why so high spec? The LCD monitor supplies 12V (for backlights - maybe 1amp) + 5V (for video/audio) and it looks like a standard supply layout with this diode is on the low voltage side. So why 150V 5 Amps? I'm wondering if I could get away with a smaller device like 3A 100V (or less)...?
But on the other hand if it was over-rated then why did the original die?
Also, after quite some googling I'm still not clear on a Schottky Barrier vs 'normal' Schottky diode other than junction capacitance... but I don't understand the implications of this. I have urges to stick in any old diodes I find in some dead computer PSUs and hope it works....?????
Can someone familiar with switchmodes comment on likely substitutes?
thank you
Mike
Link to comment
Share on other sites
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
