Capacitor charging using low voltage supply
hubble
In my previous thread, I had posted a question regarding the nature of waveform generated by stepper motor. I measured emf generated by motor using DMM and the Vrms was just over 5V. As I am not having the oscilloscope, I tried to theoretically calculate the frequency of the wave. It is a 200 step motor rotating at 4 RPS, so 200*4=800 before rectification. After it passes through the rectifier it is 800*2=1600Hz (I took 1.5khz). I am not sure whether it is a correct way to calculate.
Thanks.
Capacitors are the fastest components to charge according to me. They are great for storage, especially super capacitors. I had earlier planned to use planetary gear system to increase the rpm five fold but they are not readily available here nor can I design the system myself and have them fabricated(or 3D printed) because of lack of resources. And, the motor rotary mechanism is quite small so it is really very difficult to use other type of gear mechanism.
Thanks.
I am okay with the amount of energy stored by the capacitor. Batteries, according to my information, are slow charging devices when compared with capacitors. By the way, how do I step up the voltage? Can I use some boost converter to raise it to considerable level and then use voltage doubler or something like that to achieve some efficiency? I was struggling to calculate the time required to charge the capacitor to a particular voltage. How did you calculate the capacitor charging time?
Thanks.
After days of trying to choose between different ways, I chose to go with the CW multiplier. Tried to charge for more than 30 sec with 1n4007 and 10 nF cap system, the 10 mF cap got charged to only 500 mV. I think I have chosen wrong value cap. Here, I tried to simulate with 7 VA 800Hz source, and different stages of 10 uF cap and 1n4007 in TINA, got this result as shown in the attachment. Where am I going?
Your circuit is working, at least in simulation. Increasing the values of the capacitors in the voltage multiplier circuit will speed things up. Try replacing the 10uF capacitors with 100uF capacitors.
The maximum voltage on the capacitor will always be lower than expected, due to the diode losses. Using Schottky diodes may help this but the reverse leakage current is normally a bit higher.
In reality there's also a limit on how fast the capacitor will charge as the stepper motor will have an internal impedance which will slow it down.
  • 4 weeks later...
I apologize for delay in getting back. Actually, my mom met with an accident so I had to take care of her and couldn't do any other work in these 20-25 days. But, now she is recovering well. In the meanwhile, I dropped the idea of using voltage multiplier and instead thought of using transformer. I had a 230 VAC / 12 V 200 mA adapter. Took a transformer out and connected the secondary coil to the stepper motor and measured the output at the primary: the rectified output was around 85 - 90 V. Upon connecting 22 kohm resistor, the output dropped to around 50 V. Can I use this transformer to safely charge a 63 V capacitor to 50 V?
Thanks.
The zener diode only wastes power when the capacitor has charged to 50V.
You may be able to make a precise 50V zener diode from the TL431. The problem is it's only rated to 36V but a common base amplifier can be added to boost it to 50V. The extra gain may cause oscillation though. I haven't tested it.
The efficiency of this circuit will be poor anyway.
You didn't say anything about a buck converter before.
How much current do you need to draw?
What's the point of increasing the voltage to 50V then reducing it to 5V?
According to the datasheet, the LTC3639 can work up to 150V so as long as the capacitor is suitably rating you don't need to limit it to 50V.
The data sheet shows you how to calculate component vales for a given output voltage,
http://cds.linear.com/docs/en/datasheet/3639fd.pdf
Earlier, I planned to use super capacitor of 2- 5 F 2.7 V. However, these capacitors are very expensive here, if available at all. Instead, high voltage mF caps are readily available. It is because of this reason the generator voltage is needed to be raised to high voltage of around 50 V (safe limit for a 63 V cap) to store considerable amount of energy and then the cap voltage is brought down to sub 5 V level using a high efficiency buck converter. This cap is intended to supply 20 mA max current.
Thanks.
How long does it need to last for?
I hope you're aware that you will not be able to charge the capacitor and draw 5V at 20mA at the same time.
Before you said the transformer charges the capacitor to 90V when nothing is connected to it, then it drops to around 50V when a 22k resistor is connected to it. Using  Thévenin's theorem the internal resistance of the transformer plus the stepper motor can be calculated as 17.6k. Maximum power transfer occurs when the load resistance equals the source which is when the output voltage is half the open circuit voltage so it can be calculated to be 452/17.6k = 115mW.
The datasheet for the says the LTC3639 says it's 85% efficient so the power required to give 5*0.02 = 100mW out is 0.1*0.85 = 117.6mW.
This means you can charge the capacitor as long as the buck regulator is very lightly loaded.
I would have wanted it to last for as long as it can. But for this prototype, the requirement is under 120 sec.
Yes, I am. Once the capacitor is fully charged then only the load is going to be activated.
Shall I directly connect the capacitor to the input of buck regulator?
Thanks.
