Jump to content
Electronics-Lab.com Community
Posted
I do not need to use an image hosting service (that loses an image after a while) on any other website I post attachments on so why do it here? The new software here should be fixed so that Windows 8.1 with internet Explorer 11 works with it.
Posted
I still do not see a box at the lower left corner that will allow me to make an attachment. The area where it might be located is shaded a little with the "Insert Other Media" box on the lower right side.
Posted (edited)
I followed instructions in Google how to clear the browser cache and clear temp files. I rebooted. I needed to log in here but I still do not see a box to allow me to make an attachment.
Hero and you use an older Windows 7 operating system. I use newer Wndows 8.1 Pro.
Edited by audioguru
Posted
I went to my Profile to try to set the clock here but couldn't find the clock. I found where it said my gender is Female! Ha,ha, ho, ho, haw, haw. I changed it to male.
How do I set the clock here? How do I set a photo for my avatar?
Posted
It seems there is no need to set the clock on your profile. Forum takes the timezone from your PC. Gender issue is probably caused by forum migration, i am sorry for that.
To change the avatar, you just click on the profile photo icon on your profile.
Posted
I set my Avatar photo but I still do not have a box allowing me to attach anything. I will check my clock here since it it 9:53AM where I am.
Let me see the time here.
The clock does not show on my post, it might show later
Posted
Did you upload your avatar from your hard drive or somewhere else on the Internet?
Usually I'd advise you install all the relevant updates for your browser and operating system but I'm able to post attachments from my work's PC which is running an old version of Firefox.
Posted
In my profile I see the box allowing me to upload my Avatar from my hard drive. But in a forum reply here I do not see a box allowing me to make an attachment.
My pc automatically gets all the latest updates from Microsoft.
My browser had its "popup blocker" turned on, I turned it off now and I will try another reply in a minute.
With the 'popup blocker' in my browser turned off, I still do not see a box in my reply allowing me to make an attachment.
A minute ago I made this same reply and clicked on Submit Reply. Then it said "Saving" forever but never saved it so here it is again.
  • 2 weeks later...
Posted
I upgraded my pc operating system to Windows 10 and its browser is called EDGE. It works fine on other forums so I will try to attach a file here.
Like with Windows 8.1 and the browser Internet Explorer 11 there is no button here for me to click for me to attach anything.
Posted
I am sorry to see that the problem didn't go away with the upgrade to Windows 10. So I now suspect that something else is blocking the button to appear on your pc. Do you use any special plugins on your browser, like ad blockers etc? Also, have you tried to deactivate your antivirus temporary?
Posted
This time I changed Windows 10 to Internet Explorer mode then I needed to log in here again. I still do not see the button for attachments.
I also looked at Internet Explorer addons and millions of advanced settings but I did not see a javascript plugin.
I do not know how to turn off my AVG Free anti-virus program.
Posted
In Windows 10 I turned off its popup blocker and turned off its Smartscreen Filter. Then I re-booted and checked that they are still turned off.
I still do not see the attachments button.
I looked at how to add JavaScript but it said to do many things I do not know how to do.
Posted
The browser called EDGE in Windows 10 does not support plugins so I installed Java on Internet Explorer that I am now using.
I still do not have a button for attachments. Anti-virus is turned on.
I added Java, re-booted then checked that Java is active. I changed from Browser Edge to browser Internet Explorer (a nuisance) so that Java is running. I disabled AVG anti-virus and I STILL CANNOT ATTACH  ANYTHING. Is there anything else I can do? Other electronics forums work perfectly.
  • 1 month later...
Posted
Using the EDGE browser on Windows 10 when I clicked on "reply" it filled in the text I already posted a week or two ago.
When I changed the browser to Internet Explorer then I needed to log in (again) and go through a few pages to find this thread.
I will try to post an attachment, but I can't since the box that I must click on is not showing and when I hover my mouse pointer over where the box should be then nothing happens.
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
