howlingmadpanda Posted January 26, 2016 Report Share Posted January 26, 2016 For some time I have been working with some more basic electronics projects and have been familiar with electronic theory and the physics behind it. I have now begun working on a geiger counter project, which has gone well for the most part. All of my actual electronics (creating GM tube voltage, detection or ionising radiation) have worked fine. I have only recently, however, begun to work with interfacing an LCD with a PIC18F4550. My intended use of this is to display CPM digitally -- x number of counts in a certain amount of time, display to LCD. I am familiar with PIC Timers, so I didn't think there would be an issue with that code. My issue here is that I attempted to write a "hello world" program on my 16x2 LCD, of course partially skidding the code from online as I had never used an LCD with a PIC before. I know that my PIC is hooked up to the LCD correctly and I am getting current on the pins, implying that a signal is being sent. Could anybody help?Code:<code> #if defined(__XC) #include <xc.h> #elif defined(HI_TECH_C) #include <htc.h> #endif#include <stdint.h> /#include <stdbool.h> #include <xc.h>#include "system.h" #include "user.h" #include <htc.h>#define _XTAL_FREQ 1000000#define rs RA0#define rw RA1#define en RA2//LCD Data pins#define lcdport PORTBvoid lcd_init();void lcdcmd(unsigned char);void lcddata(unsigned char);unsigned char data[20]="hello world";unsigned int i = 0;void main(void){TRISA=0; // Configure Port A as output port//PORTA=0;TRISB=0; // Configure Port B as output port//PORTB=0;lcd_init(); // LCD initializationwhile(data != '\0'){lcddata(data); // Call lcddata function to send characters// one by one from ?data? arrayi++;__delay_ms(300);}}void lcd_init(){lcdcmd(0x38);lcdcmd(0x0C);lcdcmd(0x01);lcdcmd(0x06);lcdcmd(0x80);}void lcdcmd(unsigned char cmdout){lcdport=cmdout;rs=0;rw=0;en=1;__delay_ms(10);en=0;}void lcddata(unsigned char dataout){lcdport=dataout;rs=1;rw=0;en=1;__delay_ms(10);en=0;} </code> Quote Link to comment Share on other sites More sharing options...
ZomBiE80 Posted January 26, 2016 Report Share Posted January 26, 2016 http://www.circuitsgallery.com/2013/09/lcd-interface-with-microcontroller-pic.html Quote Link to comment Share on other sites More sharing options...
