gea riosa Posted May 5, 2016 Report Share Posted May 5, 2016 hi! how to do the countdown timer from 555 to bcd to decoder? also the 7-segment display. If possible, let me have the schematic diagram. thank you. Quote Link to comment Share on other sites More sharing options...
pebe Posted May 5, 2016 Report Share Posted May 5, 2016 Feed the 555 output into a CD4026B. That will give you a 16 stage counter with 7segment output. Use the chip's 'carry out' to cascade further 4026 ICs if you require more than one 7segment display. Quote Link to comment Share on other sites More sharing options...
vlady_2009 Posted July 28, 2016 Report Share Posted July 28, 2016 I have an example of a tally or event counter based upon a CD4553 BCD counter IC in conjunction with a CD4511 BCD-to-7 segment driver with three 7-segment LED displays. This could be easily modified to feed in the 555 output as the trigger for counter/tally. Have a look at the following site which has full schematics and construction details etc. http://www.fadstoobsessions.com/Electronics-Projects/DIY-Tools/Digital-Counter.php Quote Link to comment Share on other sites More sharing options...
