Jump to content
Electronics-Lab.com Community
Sign in to follow this
johnsmith1212
Practical use of voltage divider
hello,
I am stuck with a dilemma which might or might not have a simple solution.
more: giá chung cư 17 phạm hùng
I have a psu supplying 46Vdc
unofrtunately i need to step this down to several different voltages.
1) 14 to 20Vdc (best would be 16Vdc) to power a micro mainboard power supply thingy, using approx 100W
2) 12Vdc form as well a led strip, a fan, temperature sensors (LM35 i believe) and arduino atmega 2560 board
3) 5Vdc
so i was thinking (maybe wrongly) to use a couple of 100W resistors in series (5KΩ - 5KΩ - 5KΩ&2KΩ - 2KΩ) and use it as voltage dividers.
if I calculate correctly this should give me
2/19 * 46 = 4.8Vdc
5/19 * 46 = 12.1Vdc (2 times)
7/19 * 46 = 16.9Vdc
more: giá căn hộ iris garden trần hữu dực
so going from the assumption that all this above is correct, i started to wunder if the is a problem when there is a big difference in power consumption between the different voltages. as the 16.9Vdc "rail" would use approx 90-95 Watt (also pushing to the limits of the resistors used) and approx 1A for the 5Vdc "rail"
if this is not a usable option.. is there an other way to do this correctly?
i have a step down board but this one has a max. input power limit of 40Vdc, en even though i swapped the capacitors to larger once i believe that the actually limit is defined by (an) other component on the PCB, which i would blow up. specially as it would be on 24/7
also voltage regulators can supply this power..
any advice would be highly appreciated.
more: giá căn hộ park residence lê văn lương
ps: i understand i faultly use term rail here., and no a different PSU is not an option!
Share this post
Link to post
Share on other sites
How about 3 terminal adjustable voltage regulators?
see for example: https://www.mouser.com/ProductDetail/ON-Semiconductor-Fairchild/LM317AHVT?qs=%2fha2pyFadugRpOCsw7uJG%2fYkcWjLe5SQfHkipQZSRvGAuHf8Q8Z20lpgQCwyK1vllMxUP7WNhWIGj0RAnAK1dQ%3d%3d
60 volts max and 1.5 amperes. Poke around at Mouser for higher current ones also. There are filters on their site that are helpful.
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
