Aman bharti Posted August 13, 2018 Report Share Posted August 13, 2018 http://www.circuitspedia.com/blinking-led-flasher-circuit-diagram-with-555/ http://www.circuitspedia.com/simple-5-led-blinker-flasher-circuit-blinking-led-running-chaser-light/ 17 LED Sequencer/Flasher Circuit using 2 Counter ic 4017 Dual colour led flasher circuit For more circuit go to circuitspedia.com Quote Link to comment Share on other sites More sharing options...
audioguru Posted August 13, 2018 Report Share Posted August 13, 2018 Using a single color red LED: A CD4017 powered from 9V can output 16mA into a 2V red LED on each output which is enough to burn out its output transistors. Use 150 ohm series current-limiting resistors to share the heat. Quote Link to comment Share on other sites More sharing options...
