HackoBoy Posted June 9, 2019 Report Share Posted June 9, 2019 Hello guys I have one request. I bought a hot air station .This device - at a low price - where the main role for the job is using a microcontroller HR7P169 There is a connector option on the PCB and I suppose it is for reading and overwriting. After the station for me was 30 euros and the microcontroller for almost 2 euros. What will be needed to try reading the code and having it as a file this device is powered directly to the electrical outlet to the white connector, and when I set the temperature, I see the heater flashing differently according to the temperature and the power of the air jet. When placed, the stand stops heating and only blows while it is needed or if it reaches 100 degrees and shuts down Chips using in this device : Upper left -> Eastsoft HR7P169BFGTF Upper right -> F7103 in the middle on pcb -> LM358 in the below the transformer -> PN8370 Using moc3023 who the control bta12/800A Quote Link to comment Share on other sites More sharing options...
HarryA Posted June 10, 2019 Report Share Posted June 10, 2019 As only the CPU has access to the flash memory I would think it would not be possible to access the code. If it were on a separate chip you could read it with the right equipment. It may be better to develop your own code rather then try to reverse engineer this device. chip you Quote Link to comment Share on other sites More sharing options...
HackoBoy Posted June 10, 2019 Author Report Share Posted June 10, 2019 After I did not see the board name (usually write the PCB model), I removed the front panel. But obviously this is a super new version of a PCB and there is no information. If the connector ( sck sda rst vcc gnd ) ... I now see that some of the captions are used in the oled displays. And it's actually programmed or connected to a display instead of a 7-segment indicator ? Quote Link to comment Share on other sites More sharing options...
need2know Posted December 28, 2022 Report Share Posted December 28, 2022 Is that the only tranformer running this whole device at such high heat Quote Link to comment Share on other sites More sharing options...
