Jump to content
Electronics-Lab.com Community
BQ76PL536 sampling problem
malugu
In the test BQ76PL536PAPT sampling process, it is found that when a channel inputs a signal with periodic interference, the BQ sampling is abnormal. We superimpose a 1KHz peak-to-peak 5V square wave into the BQ sampling circuit, which will act on the CELL2 channel equalization MOS tube to achieve periodic changes in the input voltage.
Finally, a triangular wave with a period of about 17s is obtained. I don't know where the problem is.
Link to comment
Share on other sites
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
