Jump to content
Electronics-Lab.com Community
variable square wave 100 volt 50 amp power supply
Sedman  Smythe
Hi
I am looking for a bit of direction with a project .
Some time ago I bought a Spark Eroder or EDM (Electrical Discharge Machine) Mechanically it is very sound, but the power supply is I think beyond economic repair.
As I  understand the power supply  it works between 0 volts and 100 volts Square Wave with a variable output current from 10 to 50 Amps.
Also both the off time and the on time are separately adjustable.
I believe the original system used a lot  of power transistors which were switched by push buttons to obtain the correct power setting.
I am sure someone out there with a better understanding of modern electronics will have a good idea of how to achieve the supply I need to build.
Thank for looking, any pointers would be very much appreciated.
Jonathan Smythe
Link to comment
Share on other sites
That sounds like a major project. One would want to use a microcomputer as it would  simplify the circuitry greatly.
Example: https://www.youtube.com/watch?v=9IWWa0xCd04&feature=emb_logo
It is said that power supplies are less expensive today for EDM machines, perhaps you could search on the internet for a good price. I would thing that 2950 pounds is expensive:
https://baxedm.com/product/bx17-arc-generator/
I have an eight inch steel disk that I want to make a 100 tooth sprocket from - an electrical discharge machining would be great for that I would think.
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
