Jump to content
Electronics-Lab.com Community
kidong
SUBWOOFER COOLING FAN VARIABLE OPERATION
Hi everyone my new subwoofer with cooling fan dependent on temperature which does not run upon power up. Several hours of continuous operation listening music at home with lower volume wherein the fan is still not running but I can sense 45degC on its metal casing. I wish to revised the fan circuit to permanently running upon power up for optimum protection of amplifier circuit. I wish to have your comments if what I will doing is correct.
Share this post
Link to post
Share on other sites
I would think that is a good solution. A more elegant solution would be to use a temperature control switch in series with the fan. They are not very expensive.  You want one for example: less than 25 degrees normally open and higher than 25 degrees normally closed.
https://www.ebay.com/itm/Temperature-Switch-Control-Sensor-Thermal-Thermostat-25-C-77-F-N-O-KSD301-q-e/333383230245
The admin fixed the ugly url - looks a lot better 😀
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
