stspringer 0 Posted March 1, 2020 Report Share Posted March 1, 2020 Hi all, New to electronics, found circuitlab and I made a car turn signal hazard light schematic. I would like to know if I did it correctly "the layout" any tips appreciated Thanks Quote Link to post Share on other sites
HarryA 13 Posted March 1, 2020 Report Share Posted March 1, 2020 You should draw the fuse F1 as a blown fuse, you have a short circuit by the wire/conductor on the right. That was a test right? To see if anyone really looked at it 😉 Isn't the 7805 a voltage regulator? Not a flasher? What are the" flashers" connected to? Shouldn't they connect to the anode leads of the LEDs rather then the LEDs connecting to the Low Beam Terminal? What happens when the left and right flashers and the hazard flashers are on at the same time? Maybe okay. Could the DPDT switch be replaced with a SPST switch? Also on your SPDT there is no off position. Otherwise the schematic looks better than my poorly hand drawn schematics. Quote Link to post Share on other sites
HarryA 13 Posted March 1, 2020 Report Share Posted March 1, 2020 The LEDs flash alternating. The flash rate is determined by C1 and R4. There are online calculators for determining these values. Just supply power for the hazard signals. Supplying power and disabling one or the other LED for the turn signal. Redraw the circuit with circuitlab and add a DPDT switch with center off perhaps for the turn signal. Quote Link to post Share on other sites
stspringer 0 Posted March 2, 2020 Author Report Share Posted March 2, 2020 4 hours ago, HarryA said: You should draw the fuse F1 as a blown fuse, you have a short circuit by the wire/conductor on the left. That was a test right? To see if anyone really looked at it 😉 Isn't the 7805 a voltage regulator? Not a flasher? What are the" flashers" connected to? Shouldn't they connect to the anode leads of the LEDs rather then the LEDs connecting to the Low Beam Terminal? What happens when the left and right flashers and the hazard flashers are on at the same time? Maybe okay. Could the DPDT switch be replaced with a SPST switch? Also on your SPDT there is no off position. Otherwise the schematic looks better than my poorly hand drawn schematics. This was not a test. This circuit works. Those are flashers, they get power from 12 v battery and the out terminal the "load" terminal goes to each switch. The DPST has just the off or on position to turn on both led's at the same time and the flasher, flashes them at the same time. "Could the DPDT switch be replaced with a SPST switch?" It's a DPST switch it feeds both led's with 1 throw. Thanks for liking my schematic. Quote Link to post Share on other sites
QiHall 1 Posted December 16, 2020 Report Share Posted December 16, 2020 Thank you for such a valuable information. I was looking for a long time detailed explanation. Really appreciate your reply! Very often I like to draw diagrams and perform various tasks in physics, solve problems and enjoy it. But sometimes, due to work, there is simply not enough time for it. It's very cool that in the modern world there are services https://assignmentbro.com/uk/physics-assignment-help that can help you complete written physics assignments quickly and efficiently. In order to order a written assignment you just need to mention whatever you think about the paper. Let them know the type, timeframe, specific requirements, or anything else you deem appropriate. After that, you have the function of choosing a person who will perform the task, and you can also follow the task. Quote Link to post Share on other sites
