HarryA Posted March 23, 2020 Report Share Posted March 23, 2020 In the photography is the "Ultrasonic HC-SR04 distance measuring transducer sensor". "HC-SR04 consists of ultrasonic transmitter, receiver, and control circuit. When triggered it sends out a series of 40KHz ultrasonic pulses and receives echo from an object. Power supply: 5V DC; quiescent current: less than 2mA; effectual angle: less than 15°; distance: 2cm - 500cm." The sensor is 1.75 inches/ 4.45 cm by 0.75 inches/ 1.9 cm. The IC on the bottom left is an LM324 quad op amp. The two on the right are not marked. // The sensor is triggered by a HIGH pulse of 10 or more microseconds. Give a short LOW pulse beforehand to ensure a clean HIGH pulse: digitalWrite(iTrigPin, LOW); //pin 12 Out delayMicroseconds(5); digitalWrite(iTrigPin, HIGH); delayMicroseconds(12); digitalWrite(iTrigPin, LOW); // Read the signal from the sensor: a HIGH pulse whose duration is the time (in microseconds) from the sending of the ping to the reception of its echo off of an object. pinMode(iEchoPin, INPUT); //pin 13 In lDuration = pulseIn(iEchoPin, HIGH); The photography shows the trigger pulse in blue and the signal from the sensor in yellow bracketed by the white cursors. In the lower right is the width of the pulse: 24.4 ms from a object at 16 inches/ 40.6 cm from the sensor. // Convert the time into a distance - long way for clarity lCM = (lDuration/2) / 29.1; // Divide by 29.1 or multiply by 0.0343 lInches = (lDuration/2) / 74; // Divide by 74 or multiply by 0.0135 So for 2440 us/2 = 1220/74 = 16.48 inches or 1220/29.1 = 41.9 cm Quote Link to comment Share on other sites More sharing options...
HarryA Posted March 29, 2020 Author Report Share Posted March 29, 2020 An experimental blind spot monitoring (BSM) for an automobile. One can attach the sonic sensor on the rear section of the automobile. I mounted mine on the flap door that covers the gasoline cap. I used a length of good duct tape that wrap around the inside of the flap door also. I ran a length of 4 wire telephone cable from the sensor through the backdoor gap into the backseat. Then a length of 2 conductor wire from the Arduino Uno to the dash for a white LED. The LED has an 68 ohm resistor in series with it. The LED and resistor lives in the plastic tube For the Arduino Unio one can control the LED blinking without using the Delay() by: int iLEDstate = LOW; // used to set the LED state const long lInterval = 1000; // interval at which to blink (milliseconds) unsigned long lPreviousMillis = 0; // will store last time LED was updated int iDashLED = 10; // LED on/off pin pinMode(iDashLED, OUTPUT); //only distances more than 3 ft and less than 12 ft if(lInches > 36 && lInches < 144 ) { Dash_LED_Blink(); //blink the LED } else if (iLEDstate == HIGH) { iLEDstate == LOW; digitalWrite(iDashLED, iLEDstate); //make sure LED is off } void Dash_LED_Blink() { // check to see if it's time to blink the LED unsigned long lCurrentMillis = millis(); if (lCurrentMillis - lPreviousMillis >= lInterval) { // save the last time the LED blinked lPreviousMillis = lCurrentMillis; // if the LED is off turn it on and vice-versa if (iLEDstate == LOW) { iLEDstate = HIGH; } else { iLEDstate = LOW; } // set the LED with the iLEDstate digitalWrite(iDashLED, iLEDstate); } } Quote Link to comment Share on other sites More sharing options...
