MENG XI Posted April 13, 2020 Report Posted April 13, 2020 (edited) One of the most useful IoT applications is home security. Imagine a thief cutting your security camera wire while trying to break into your house. This won’t happen if your security system goes wireless and smart. This project demonstrates the capability of Realtek Ameba dev. board to conduct board-to-board communication via MQTT (FREE MQTT broker hosted at cloud.amebaiot.com). With this home security system, you will definitely be alarmed when your window/door is opened by the self-invited as the buzzer will make loud irritating noise while red LED flashes continuously. Of course, this project has left rooms to add your own logic to it. For example, sending MQTT messages to your phone to alert you, or to an IP camera to capture the image of the thief. Hardware Preparation - Ameba1 RTL8195AM x2 - Buzzer x1 - LED (red) x1 - Reed switch x1 - Magnet x1 - Jumpers x6 As 2 boards are needed to implement this project, there are 2 connection illustration as follows, https://github.com/Realtek-AmebaApp/Ameba_Examples/blob/master/RTL8195AM/006_HOME_SECURITY/WindowSecuritySystem_Switch_bb.png https://github.com/Realtek-AmebaApp/Ameba_Examples/blob/master/RTL8195AM/006_HOME_SECURITY/WindowSecuritySystem_Buzzer_bb.png Software Preparation 1. Check and make sure you have installed the ameba 1 board to Arduino IDE via adding this link into “additional boards manager URLs” under “Preference”, and install it in “board manager” under “Tools”, https://github.com/ambiot/amb1_arduino/raw/master/Arduino_package/package_realtek.com_ameba1_index.json 2. Copy the [buzzer source code](https://github.com/Realtek-AmebaApp/Ameba_Examples/blob/master/RTL8195AM/006_HOME_SECURITY/windowSecuritySystem_buzzer_Github.ino) and [switch source code](https://github.com/Realtek-AmebaApp/Ameba_Examples/blob/master/RTL8195AM/006_HOME_SECURITY/windowSecuritySystem_switch_Github.ino) you find in this repository to your Ameba1 RTL8195 boards respectively using arduino IDE 3. In order to connect to WiFi and MQTT server, you need to key in your WiFi SSID, WiFi passowrd, MQTT username and MQTT password, - username: same as your amebaiot.com username - password: same as your amebaiot.com password Done that's it! You have created a simple yet powerful home security system! To watch how how it is done, click link below, Edited April 13, 2020 by MENG XI add tags Quote
Evan Parker Posted June 30, 2022 Report Posted June 30, 2022 That's actually convenient, but I can tell you that it may take a while to find a reliable system that works without any lags. Quote
Charly Flint Posted June 30, 2022 Report Posted June 30, 2022 You're right, and it took me some time to find a system that's not only security one, but also with home automation. I managed to find an ajax system, and I can tell you that it's really convenient because it didn't take me long to install everything, so you can check it out and decide whether it's for you or not. Quote
Christian Johnson Posted January 1 Report Posted January 1 Home security is evolving with IoT, offering smarter and more efficient solutions. Imagine a thief attempting to disable your security system, only to be thwarted by a wireless, intelligent setup. Using the Realtek Ameba development board and MQTT communication, this project creates a responsive security system that triggers alarms and LED flashes when doors or windows are breached. You can further enhance it by sending alerts to your phone or integrating with IP cameras. For additional security measures, search for a locksmith near me to ensure all entry points are fortified. Quote
