Jump to content
Electronics-Lab.com Community
scroll a single line lcd arduino
If you want to help me, i have some questions.
I want to scroll  just a single line of a 20x4 display. on this line i want to write a string , then a value and at least another string. The last string will be change by a condition like this
if (percent1 > 50)
LCD.setCursor(0,1);
  LCD.print("Moisture S1: ");
  LCD.print(percent1);
  LCD.print("%");
  LCD.print(" ");
LCD.print(" Irrigation sistem OFF");
LCD.print(" ");
else
 LCD.setCursor(0, 1);
  LCD.print("%");
 LCD.print("Irrigaion sistem ON");
 LCD.print(" ");
"Moisture S1: " / percent1 / "%"/  " Irrigaion sistem OFF"
or
"Moisture S1: " / percent1 / "%"/  " Irrigaion sistem ON"
Thanks a lot!
Link to post
Share on other sites
Perhaps:
String DisplayString = " "; //a blank string
int percent1 = 0;
int OldPercent = 0;
void setup()
  //   Serial.begin(9600); //testing
void loop()
 if( OldPercent != percent1 ) //do not scroll needlessly
   //previous string - set the cursor to second line
   LCD.setCursor(0,2);
   LCD.print(DisplayString); //moves previous line down
  if (percent1 > 50)
   //new string
   DisplayString = "Moisture S1 : " + String(percent1) + "%" + " Irrigaion sistem ON";
   //set the cursor to for new first line
   LCD.setCursor(0,1);
   LCD.print(DisplayString); //new line to top of the LCD
   OldPercent = percent1;  //set new percent
  else
   //new string
   DisplayString = "Moisture S1 : " + String(percent1) + "%" + " Irrigaion sistem OFF";
   //set the cursor to new first line
   LCD.setCursor(0,1);
 } //end  loop
Link to post
or cleaner:
int percent1 = 0;
int OldPercent = 0;
void setup()
void loop()
   LCD.setCursor(0,2);
   LCD.print(DisplayString); //move previous line down
   LCD.setCursor(0,1);
  if (percent1 > 50)
   //new string
  else
   //new string
    //set the cursor for new first line
    LCD.setCursor(0,1);
} //end  loop
the first "set the cursor for new first line" code  is redundant; I can not see how to edit the code
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
