ilie Posted July 8, 2020 Report Share Posted July 8, 2020 If you want to help me, i have some questions. I want to scroll just a single line of a 20x4 display. on this line i want to write a string , then a value and at least another string. The last string will be change by a condition like this if (percent1 > 50) { LCD.setCursor(0,1); LCD.print("Moisture S1: "); LCD.print(percent1); LCD.print("%"); LCD.print(" "); LCD.print(" Irrigation sistem OFF"); LCD.print(" "); } else { LCD.setCursor(0, 1); LCD.print("Moisture S1: "); LCD.print(percent1); LCD.print("%"); LCD.print("Irrigaion sistem ON"); LCD.print(" "); "Moisture S1: " / percent1 / "%"/ " Irrigaion sistem OFF" or "Moisture S1: " / percent1 / "%"/ " Irrigaion sistem ON" Thanks a lot! Quote Link to comment Share on other sites More sharing options...
HarryA Posted July 8, 2020 Report Share Posted July 8, 2020 Perhaps: String DisplayString = " "; //a blank string int percent1 = 0; int OldPercent = 0; void setup() { // Serial.begin(9600); //testing } void loop() { if( OldPercent != percent1 ) //do not scroll needlessly { //previous string - set the cursor to second line LCD.setCursor(0,2); LCD.print(DisplayString); //moves previous line down if (percent1 > 50) { //new string DisplayString = "Moisture S1 : " + String(percent1) + "%" + " Irrigaion sistem ON"; //set the cursor to for new first line LCD.setCursor(0,1); LCD.print(DisplayString); //new line to top of the LCD OldPercent = percent1; //set new percent } else { //new string DisplayString = "Moisture S1 : " + String(percent1) + "%" + " Irrigaion sistem OFF"; //set the cursor to new first line LCD.setCursor(0,1); LCD.print(DisplayString); //new line to top of the LCD OldPercent = percent1; //set new percent } } } //end loop Quote Link to comment Share on other sites More sharing options...
HarryA Posted July 9, 2020 Report Share Posted July 9, 2020 or cleaner: String DisplayString = " "; //a blank string int percent1 = 0; int OldPercent = 0; void setup() { // Serial.begin(9600); //testing } void loop() { if( OldPercent != percent1 ) //do not scroll needlessly { //previous string - set the cursor to second line LCD.setCursor(0,2); LCD.print(DisplayString); //move previous line down //set the cursor to for new first line LCD.setCursor(0,1); if (percent1 > 50) { //new string DisplayString = "Moisture S1 : " + String(percent1) + "%" + " Irrigaion sistem ON"; } else { //new string DisplayString = "Moisture S1 : " + String(percent1) + "%" + " Irrigaion sistem OFF"; } //set the cursor for new first line LCD.setCursor(0,1); LCD.print(DisplayString); //new line to top of the LCD OldPercent = percent1; //set new percent } } //end loop the first "set the cursor for new first line" code is redundant; I can not see how to edit the code Quote Link to comment Share on other sites More sharing options...
