Jump to content
Electronics-Lab.com Community
"period and duty cycle" - electronics lab"
Hi HarryA , thanks for your reply.
I am new to programming.
I did copy what I saw from the video.  Uploaded it and it did not work as  described.
It looked like a few lines of code were missing.
Any thoughts?
Best regards.
Link to post
Share on other sites
The URL is:
https://www.youtube.com/watch?v=bIz9ektLunE
Following the link from youtube does not lead to anything useful.
The code has numinous errors. It would never run,
for spuddo:
This is a snapshot of the serial monitor displaying the output of the code below.
This is the circuit that I used. The duty control on the left. The two resistors limit the range of the output. You do not want zero duty cycle for example. The period control on the right. The resistor limits the period from going to zero for example.
The code:
// A rework of the code from the video: https://www.youtube.com/watch?v=bIz9ektLunE
void virtual_Scope();
int iDutyCyclePin = 2; //set input pin for the left pot = duty cycle
int iPeriodPin    = 1; //set input pin for the right pot = peroid
int iLedPin = 13;   //ser pin for output to LED
//float fFrequency;   //frequency = how many full periods per second or per 1000 millisedonds
float fPeriod = 10;  //value from the left pot
float fDuty = 1;
long int liPeriod, liDuty;
int iDutyPercent;
long int liHigh_Time, liLow_Time;
void setup()
  pinMode(iLedPin, OUTPUT); //declare ledpin as OUTPIN
  //Serial Port begin
  Serial.begin (9600);
void loop()
  fPeriod = analogRead(iPeriodPin);   //read the value from  the right pot = period
  fDuty = analogRead(iDutyCyclePin); //read the value from the left pot = duty cycle
  //limit the range of the duty cycle to 20 to 80 percent of the period because that is what works!
  fDuty = (fDuty*9/10000) * fPeriod ;  //with 5 volt supply
  liDuty = int(fDuty);  //for printouts below
  liPeriod = int(fPeriod);
//iDutyPercent = 100*liDuty/1024;     //cal duty cycle as percent for serial monitor  ????
  iDutyPercent = 100*liDuty/liPeriod; //cal duty cycle as percent for serial monitor
//  fFrequency = (1000/float(liPeriod));  //cal frequency in units of Hertz for serial monitor ???
 // liHigh_Time = liDuty*liPeriod/1024;   //cal high = on time   ???
  liHigh_Time = liDuty;   // high = on time
  liLow_Time = liPeriod - liHigh_Time; //cal low = off time
  Serial.println();  //new line
  Serial.print("period ");
  Serial.print(liPeriod);
  Serial.println("  milliseconds");
  Serial.print("duty ");
  Serial.print(liDuty);
  Serial.print("on time ");
  Serial.print(liHigh_Time);
  Serial.print("off time ");
  Serial.print(liLow_Time);
  Serial.print(" duty cycle ");
  Serial.print(iDutyPercent);
  Serial.println(" % ");
//  Serial.print("frequency ");  //what is frequency here?
//  Serial.print(fFrequency);
//  Serial.println(" Hertz");
  digitalWrite(iLedPin, HIGH);   //set the ledPin on
  delay(liHigh_Time);           //pause the program for  high_time in microseconds
  digitalWrite(iLedPin, LOW);   //set the ledPin off
  delay(liLow_Time);           //pause the program for  low_time in microseconds
  virtual_Scope();             //display trace
  delay(4000);                //slow down the scrolling
  //display a line of pulses
  int iHighDashes, iLowDashes;
  int iCount;
  //let one dash = 30 ms
  iHighDashes = liHigh_Time/30;
  iLowDashes = liLow_Time/30;
  iCount = 60/(iHighDashes+iLowDashes); //try to make the lengths similar
 // Serial.println(String(iCount) + "  "+ String(iLowDashes) + "  " + String(iHighDashes) ); //new line for space at top
  Serial.println(); //space at top
  while (iCount--)
     for (int i=0; i <iLowDashes; i++)
       Serial.print("_");
     for (int i=0; i <iHighDashes; i++)
      Serial.print("-");
   Serial.println(); //space at bottom
Link to post
Hi.
Thanks for your reply HarryA.
That program needed some surgery.
Ran yours and it achieved its aims.
I am needing a audio version , say five octaves that allows freq and duty cycle to vary independently.
Any thoughts.
Best regards.
Link to post
  • 3 months later...
Thanks for the info. I am very interested in how the code is written in YouTube or some social networks. This is really important to me, because I am currently writing a study on social networks and social media, using the resource https://gradesfixer.com/free-essay-examples/social-media/ as a source of information and inspiration. In my research, I compare how offline social media worked and continues to work, what information they show, what they filter and suppress. And how in social networks of our time, including YouTube, information is shown first, and only then is blocked. What can you tell us about this, what experience will you share?
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
