Jump to content
Electronics-Lab.com Community
An H-Bridge (Full-Bridge) driver is quite popular in driving loads such as brushed DC motors and it is widely used in robotics and industry. The main advantages of using an H-Bridge driver are: high efficiency, rotation direction change, and braking the motor. In this article/video, I have introduced a complete H-Bridge DC motor driver using four IR3205 power MOSFETs and two IR2104 MOSFET drivers. Theoretically, the above-mentioned MOSFET can handle currents up to 80A, however, in practice we can expect to get currents up to 40A if the MOSFET temperature is kept as low as possible, using a big heatsink or even a fan.
Link to comment
Share on other sites
On 9/5/2020 at 6:06 PM, Guy Shemesh said:
It looks very nice, I also like the layout and the fact you used polygon pours on both sides.
I think one improvement would be to make edge plating on the sides, it helps dissipate the heat off the main board.
If you can add schematics to the post that would also be interesting to see.
Link to comment
  • 1 month later...
  • 5 months later...
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
