Jump to content
Electronics-Lab.com Community
MicroPython is supported on RTL8722 -- Ameba
📣 RTL8722 MicroPython SDK alpha release
It was annouced that the popular MicroPython project has been ported to ameba RTL8722, with support for peripheral control and Python 3 syntax, you may now control RTL8722 not only with Arduino but also with Python language on the REPL. The SDK is currently in alpha stage and WiFi feature is going to release soon. If you are interested , please find links to the SDK on Github at.
Here are introduction and basic examples to this port,
MicroPython Ameba RTL8722 Documentation
Realtek's RTL8722 is a ARM Cortex-M33 based, dual-band WiFi and BLE 5.0 capable microntroller that is ideal for many IoT applications.
This is a alpha version of the MicroPython port for Ameba RTL8722 platform, details of the platform can be found here https://www.amebaiot.com/en/amebad/
1. How to build firmware?
Currently, this SDK only support building on Cygwin or Linux.
Before preceed, please make sure that you have already installed GNU make
Open Cygwin terminal/Ubuntu terminal and navigate to "\micropython_amebaD\MicroPython_RTL8722\ports\rtl8722" and then type,
$ make
2. How to upload?
There are 2 methods to upload Ameba D MicroPython image to your Ameba.
2.1 Release folder
In the release folder, there is a Double-Click-Me-to-Upload.cmd file.
First we right click on it and select 'Edit', and a notepad will open, now check your Ameba's serial COM port on your PC and update the correct one to the third last line of the file, then save the file and close it.
Now press RESET button while holding down UART Download button to enter Download Mode, and you can double click Double-Click-Me-to-Upload.cmd now and the uploading will start shortly.
2.2 port/rtl8722 folder
1st, check your ameba Serial/COM port, make sure Ameba D's port name is correctly updated in the UPLOAD_PATH variable in the Makefile;
2nd, press RESET button while holding down UART Download button to enter Download Mode, Then, type following command,
$ make upload
3. How to use MicroPython RTL8722 Port?
3.1 Brief introduction to MicroPython RTL8722 port
MicroPython distinguishes itself from other compilation-based platforms (Arduino etc.) with its powerful method of real-time interaction with Microcontroller through a built-in feature -- REPL.
REPL stands for Read-Evaluation-Print-Loop, it's an interactive prompt that you can use to access and control your microcontroller.
REPL has been equipped with other powerful features like tab completion, line editing, auto-indentation, input history and more. It basically functions like the classic Python IDLE but running on microcontroller.
To use REPL, simply open any serial terminal software (most common ones are teraterm, putty etc.) on your PC and connect to your microcontroller's serial port, then set baudrate to 115200 before reset the board, then you will see >>> MicroPython prompt appear on the console. Now you may type in any Python script on REPL as long as it's support by MicroPython and your microcontroller's MicroPython port.
3.2 REPL Hotkeys
  1. Ctrl + d : Soft reboot MicroPython will perform software reboot, this is useful when your microcontroller is behaving abnormally. This will also run scripts in 'boot.py' once again.
  2. Ctrl + e : Paste mode Paste mode allow you to perform pasting a large trunk of code into REPL at once without executing code line by line. This is useful when you have found a MicroPython library and wish to test it out immediately by copy and paste
  3. Ctrl + b : Normal mode This hotkey will set REPL back to normal mode. This is useful if you are stuck in certain mode and can not get out.
  4. Ctrl + c : Quick cancel This hotkey help you to cancel any input or interrupt currently running code
4. Peripheral Control -- umachine module
MicroPython Ameba D port supports rich peripheral feature through the use of umachine module
GPIO
To control GPIO, import Pin module through umachine. Here pin PB_18 is used as an example to output logic level 0 and 1 and blink 3 times
from umachine import Pin
a = Pin("PB_18", Pin.OUT)
a.value(1)
time.sleep_ms(500)
a.value(0)
time.sleep_ms(500)
a.on()
time.sleep_ms(500)
a.off()
time.sleep_ms(500)
a.toggle()
time.sleep_ms(500)
a.toggle()
PWM
To use PWM (Pulse Width Modulation), import PWM module through umachine. Here pin PA_26 is used as an example to make an LED to slowly brighten up
from umachine import Pin, PWM
import time as t
p = PWM(pin = "PA_26")
for i in range(1000):
p.pulsewidth(i) # this and following line will be auto indented on REPL
t.sleep_ms(2)
Delay and Timing
Use the time module
import time
time.sleep(1)           # sleep for 1 second
time.sleep_ms(500)      # sleep for 500 milliseconds
time.sleep_us(10)       # sleep for 10 microseconds
start = time.ticks_ms() # get millisecond counter
Timer
Use the Timer module through umachine module
There are 4 sets of 32KHz General Timers available to user, Timer 0/1/2/3
from umachine import Timer
t = Timer(0)  # Use Timer 0/1/2/3 only
t.start(2000000, t.PERIODICAL)  # Set GTimer fired periodically at duration of 2 seconds, printing text on the terminal
RTC
Use the RTC (Real Time Clock) module through umachine module
from umachine import RTC
rtc = RTC()
rtc.datetime((2020, 12, 31, 4, 23, 58, 59, 0)) # set a specific date and time (year, month, day, weekday(0 for Monday), hour, minute, second, total seconds)
rtc.datetime() # get date and time
UART
Use the UART module through umachine module
from umachine import UART
uart = UART(tx="PA_21", rx= "PA_22")
uart.write('hello')
uart.read(5) # read up to 5 bytes
I2C
Use the I2C (Inter-Integrated Circuit) module through umachine module
Note: I2C only works in master mode.
from umachine import Pin, I2C
i2c = I2C(scl = "PA_25", sda = "PA_26", freq=100000) # configure I2C with pins and freq. of 100KHz
i2c.scan()
i2c.writeto(8, 'hello') # send 5 bytes to slave with address 8
i2c.readfrom(8, 6) # receive 5 bytes from slave
SPI
Use the SPI (Serial Peripheral Interface) module through umachine module, currently only support Master mode, default SPI baud rate is 2MHz.
from umachine import SPI
spi = SPI(0)		# Only support 2 sets of SPI -- 0 and 1
spi 				# type instance name to check for details of the SPI set
spi.write(123)		# Write number 123
spi.read()
Link to post
Share on other sites
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
