dave Posted March 13, 2021 Report Posted March 13, 2021 HI Can i use a 6v 4.5ah battery on a camera that takes an external 6v 1.5A? as have no wish to damage camera thank you Dave Quote
HarryA Posted March 14, 2021 Report Posted March 14, 2021 Yes you can use a battery as long as it is 6.0 volts. How long it will last will depend on how much current the camera draws. If you are using 4 AA batteries there is good information here: https://www.powerstream.com/AA-tests.htm Quote
Guy Shemesh Posted March 19, 2021 Report Posted March 19, 2021 Hi Dave, Yes you can, just make sure you get the polarities right. You need to verify that the + of the battery goes to the + of the camera, and same for the -. Typically electronic circuits are protecting against this but you shouldn't try it. Just check your old battery and make sure the new battery has the + and - signs at the same locations. Best wishes Guy Quote
