Hello.
I would like to make a volume attenuator composed of bistable single coil latch relays in logarithmic resistor ladder configuration.
to do this I thought of using a binary counter 40193 whose outputs go to an operational amplifier. the function of the operational amplifier is to send a pulse to the TC4420 half-bridge mosfet (attention, only one pulse at each change of state of the 40193) which controls the relay coil. to drive the bistable latch relays it is customary to use a pulse in one direction or the other without leaving the coil under voltage all the time.
as you can see from the attached image the other end of the coil is connected to the zero of the dual power supply.
to simplify, only one component of each type appears in the image (opamp, tc4420, relay), but in the real circuit there are at least six.
the problem is the following:
which op amp should i use? and which configuration is the most suitable?
As the TC4420 accepts logic level inputs and the  40193 output is a logic level why is anything needed between them? Also both  only require a single voltage supply (Vdd) for the circuit shown a dual supply would not be required. There are single Vdd supply op amps  if you need  one.
I have a circuit that uses a TC4420 driven directly via a Arduino Uno output.
Step 1:
Are you committed to using to using the TC4420 and 40193?  Consider using a circuit like the one below. The direction of current flow  through the relay coil depends on which transistor is on.  Also if you do not have the relays yet these may simplify your design:
https://www.amazon.com/SMAKN-Trigger-Switch-Latching-controlled/dp/B01CN7V0F6/ref=sr_1_20?dchild=1&keywords=latching+relay&qid=1617978673&sr=8-20
What are you using of inputs to the circuit?
