Jump to content
Electronics-Lab.com Community
Posted
سلام ، من به یک مدار دمنده اتومبیل دیجیتال با قابلیت تنظیم فشار با سنسور فشار 10 بار 5 ولت با خروجی 0.5 تا 4.5 ولت نیاز دارم.
Posted
"Hi, I need a digital car blower circuit with the ability to adjust the pressure with a pressure sensor 10 times 5 volts with an output of 0.5 to 4.5 volts."
Sorry Google does not translate Persian into English well. What is "a pressure sensor 10 times 5 volts" ?
با عرض پوزش ، فارسی را به انگلیسی ترجمه نمی کند. "سنسور فشار 10 برابر 5  ولت" چیست؟
You may find this  translator helpful:
به نظر شما این مترجم مفید است
https://translate.google.com/
Posted
Digital inflator .
With 10 bar pressure sensor.
The type of sensor is 5 volts with an output of 0.5 to 4.5 volts.
thank you
Digital inflator .
thank you
Posted
Sorry but you must tell us what you have now to work with and what are your goals. Do you have a sensor or need to find one to buy? What type of air pump or inflator do you have or need?
If you need a sensor this company has 1 - 5 volts  ones that you could subtract 0.5 volts from as an example.
https://www.sensorsone.com/10bar-150psi-0-10v-0-5v-1-5v-pressure-sensors/
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
