Good day, allΒ πŸ™‚
Recently, I have a system running at 62V max, 54V nominal based on voltage divider rule formula. I wanted to have a little alert LED, so I was thinking about using 10, 1kohm resistors, and adding the LED bewteen the 9th and 10th (or 1st and 2nd, if it matters), to get at most 6V and just a few mA.Β
Is a better/easier way? Is this a really crappy way? Or is this a perfectly fine way? 😢
Voltage Divider Basic and Rule.pdf
Thank you for helpingΒ πŸ™‚
I have a bunch of 1k, 1/4W resistors, so 10 of those will work fine. I guess that 6mA at 60V is only 360mW, which might be a bit high. I could always use a lot more resistors and experiment by reducing it until I get to a suitable brightness.
