max-bit Posted September 2, 2021 Report Share Posted September 2, 2021 As in the topic, the problem of a large number of adapters : NI GPIB-USB-HS From software version 17.6 (NI 488.2) all Chinese adapters (mainly bought on ebay) are detected as not genuine. So far the solution is to use software version 17.0 (which is also not available on the NI website). But is this the only solution? According to me, there should be at least 2 more: 1 - finding a module (entry) in the software which, after detecting an incorrect number, throws this error. 2 - (or even better) find the entry in the adapter's flash memory where the serial number is and change it Has anyone tried to deal with the topic? So far, I have not been able to find such an entry neither in the software nor in the memory of the adapter, most likely this value is encrypted in some way. and ... ... programmed eeprom 24lc256 (from original unit) serial no. changed in NI MAX but software still sees it as not genuine? WTF? (on version NI MAX > 17.0 ... actual 21) Quote Link to comment Share on other sites More sharing options...
HarryA Posted September 2, 2021 Report Share Posted September 2, 2021 You can find information on the subject at the NI subforum: https://forums.ni.com/t5/Instrument-Control-GPIB-Serial/bd-p/140?profile.language=en The NI discussion forum starts here: https://forums.ni.com/t5/Discussion-Forums/ct-p/discussion-forums?profile.language=en Quote Link to comment Share on other sites More sharing options...
max-bit Posted September 2, 2021 Author Report Share Posted September 2, 2021 On NI website How to Hack NI GPIB-USB-HS interface HACK ? .... Quote Link to comment Share on other sites More sharing options...
max-bit Posted September 3, 2021 Author Report Share Posted September 3, 2021 and ... What do you think may still ask if NI provide tools to circumvent the blockade? Will it succeed?😁🙄 Quote Link to comment Share on other sites More sharing options...
