Electronic Component: CL220 Regulator
KAKU
CL220 is a high voltage, temperature-compensated, 20mA constant current regulator. The device operates at up to 220V, and is accurate to ±10% over a 5 - 160V range. The device can be used as a two-terminal, constant-current source or a constant-current sink.
CL220 Features
5.0 to 220V operating range (VA-B)
20mA ±10% at 5.0 - 160V
0.01% / °C typical temperature coefficient
Packages Types:
- TO-252 (D-PAK)
Can be paralleled for higher current
  • 4 weeks later...
  • 10 months later...
The CL220 is a temperature compensated, high-voltage constant-current regulator that operates over a wide range of voltages up to 220V. This device operates as a two-terminal constant-current source or sink and is commonly used to drive LEDs with a constant current of 20mA. Multiple CL220s can be used in parallel to increase current capacity. The CL220 comes in a TO-220 package for easy installation and is available in several configurations.
