Jump to content
Electronics-Lab.com Community
36V-3A Adjustable Efficient DC to DC Step-Down Converter
A DC-to-DC converter is one of the most commonly used circuit topologies in electronics, especially in power supply applications. There are three major types of DC-to-DC converters (non-isolated): Buck, Boost, and Buck-Boost. Sometimes a buck converter is also called a step-down converter and a boost converter is also called a step-up converter.
In this article/video, I introduce an adjustable buck converter circuit that uses an advanced converter chip, made by Texas Instruments, which is TPS5430. It’s a high-frequency and 95% efficient chip. In the PCB layout design of such converters, several PCB design rules should be followed, otherwise, the circuit might generate a significant amount of radiated emission and suffer output instability.
To design the schematic and PCB, I used Altium Designer 22 and used the manufacturer part search feature to directly import the components into the PCB project. Then, generated the BOM list using the free OctoPart services. To get high-quality fabricated boards, I sent the Gerbers to PCBWay and tested the circuit for output stability and noise, using a DC load, A multimeter, and an oscilloscope. Soon later, I will also perform the step-response test and demonstrate the results. Stay connected!
Specifications
Input Voltage: 5.5V to 36V
Output Voltage: 1.22Vmin (variable)
Output Current (continuous): 3A
Output Current (peak): 4A
Maximum output voltage drop: 10mV (3A load)
Output Noise: 12mVp-p (no load), 43mVp-p (3A load), 20MHz-BW
References
Ref: https://www.pcbway.com/blog/technology/36V_3A_Adjustable_Efficient_DC_to_DC_Step_Down_Converter_aca08813.html
[1]: TPS5430: https://octopart.com/tps5430mddarep-texas+instruments-12192395?r=sp
[2]: B360B-13-F (or SS34, SMB package): https://octopart.com/b360b-13-f-diodes+inc.-325834?r=sp
Link to comment
Share on other sites
  • 6 months later...
Specifications
References
8 ball pool hack
One voltage step is typically more efficient than additional steps, i.e., use one converter for each desired output stepping down once form the source voltage, 14-12, 14-9 and 14-5. Worth noting that your 4S LFP won't be at 14V for very long. You'll rapidly drop into the low to mid 13s under load. 2-3) don't know. 4) No, but % efficiency is more related to the power being converted. Very low power tends to be very inefficient. Moderate power tends to be efficient (92% "max"), max power tends to be a little less efficient. "Power" is relative to rated power, i.e., 0.5W on a 50W unit would be very inefficient, but 0.5W on 1W unit would be very efficient. 5) I suspect they may drift slightly with temperature. I'd put a small LED voltmeter on each output for fun.
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
