Newbie needs advice on making continuity LED box.
I currently have a LED box that I used to test continuity on a 28 pin circular connector. See attached photo. Pin 1 when probed (probe is attached to box) on the circular connector corresponds to LED 1, etc.
I would like to make a digital display version of this.
Any help appreciated on components needed, circuit examples, etc.
You could use an Arduino Mega 2560 as it has enough digital input/output pins for your 28 connections. Other micro-controllers may work but I only know the Arduino controllers.
Do you need more than a simple one line display?  "Yup pin 13 is okay"
If it interest you, I could program the micro-controller for you.  That would give you an introduction to micro-controllers. The micro-controller is about 21$, a LCD  about 13$, You would need a 9 volt battery, a battery connector, a battery to micro_controller connector, and a switch also.
An assortment of colored wire would be helpful. Plus a plastic or metal box to pack it all into.
If you are checking your cables near a computer you could uses the computer as a simple display device instead of the LCD.
LCD : https://www.amazon.com/SunFounder-Serial-Module-Arduino-Mega2560/dp/B01GPUMP9C/ref=sr_1_1_sspa?adgrpid=1335907194272933
Micro-controller: https://www.amazon.com/ELEGOO-ATmega2560-ATMEGA16U2-Arduino-Compliant/dp/B01H4ZDYCE/ref=sr_1_2_sspa?crid=1L06F0IP302BX&keywords=Arduino+R3+Mega2560&qid=1684882151
wire: https://www.amazon.com/TUOFENG-Hookup-Wires-6-Different-Colored/dp/B07TX6BX47/ref=sr_1_3?keywords=colored+wire+spool&link_code=qs&qid=1684885902&sourceid=Mozilla-search&sr=8-3
The Mega 2560 has 54 digital I/O pins plus 16 analog pins for a total of 70. You lose  2 pins for the display for either  the PC  display or LCD. You can have speech on the PC for free.
You may need a larger LCD for numerous pins. Mapping the Mega pin numbers to the cable pin numbers would have to be predetermined.  Some connectors use alpha characters (A - Z) I gather.
