Jump to content
Electronics-Lab.com Community
Will guide you to install Home Assistance on Raspberry Pi 4.
Things used in this project
Hardware components
Raspberry Pi 4 Model B
× 1
Story
To use most smart home devices, you need to download an app, create an account, and link them to an online cloud server. This makes them easy to control, but it also means that your usage data, such as when, where, or how you operate your devices, is stored online and may not be private. If you care about privacy, you can try Home Assistant, a software that lets you manage your smart IoT devices and automate your smart home locally —without any cloud connection or integration.
Home Assistant:
Home Assistant is a free, open-source, and lightweight home automation software that runs on top of Home Assistant Operating System.
image_V3RpIKjEXn.png?auto=compress%2Cfor
Home Assistant OS can be installed and configured on Raspberry Pi 4, which is a low-power and compact device for running Home Assistant.
Get PCBs for Your Projects Manufactured
1_kedzfumByE.JPG?auto=compress%2Cformat&
You must check out PCBWAY for ordering PCBs online for cheap!
You get 10 good-quality PCBs manufactured and shipped to your doorstep for cheap. You will also get a discount on shipping on your first order. Upload your Gerber files onto PCBWAY to get them manufactured with good quality and quick turnaround time. PCBWay now could provide a complete product solution, from design to enclosure production. Check out their online Gerber viewer function. With reward points, you can get free stuff from their gift shop.
Step 1: Flash Home Assistant OS
Download the Home Assistant OS image for your Raspberry Pi 4 64-bit using this hyperlink.
https://github.com/home-assistant/operating-system/releases/download/7.3/haos_rpi4-7.3.img.xz
Then download, install, and open the Raspberry Pi Imager tool to flash the Home Assistant OS image to an SD card.
image_ZwTFYu7xcv.png?auto=compress%2Cfor
In the Imager tool first select the downloaded OS image.
image_v4qU4uy60u.png?auto=compress%2Cfor
Click Storage and choose the connected Micro SD card.
image_wbfuTXjz9y.png?auto=compress%2Cfor
Click Write and wait for the process to complete. This may take a while.
image_MVVCKBC7Aa.png?auto=compress%2Cfor
After the Home Assistant OS image is flashed successfully, eject the Micro SD card, and connect it to the Raspberry Pi’s card slot.
image_wfSjl184Ur.png?auto=compress%2Cfor
Step 2: Boot Raspberry Pi
To boot Home Assistant, connect the LAN cable to the Ethernet port on Raspberry Pi. Connect the power supply to turn on the Raspberry Pi. Wait for a few minutes as it boots and updates. This can take up to 10-20 minutes.
image_TgFQAs4gU2.png?auto=compress%2Cfor
Step 3: Setup Home Assistant
To set up and configure Home Assistant, open the web browser, and go to http://homeassistant.local:8123.
image_VFWwFIY5o8.png?auto=compress%2Cfor
If that standard URL is down open your router admin page and find the IP address of the raspberry pi. Then type the IP address of your Raspberry Pi in the web browser, such as http://xx.xx.xx.xx:8123. Alternatively, you can use the android application for home assistance.
image_tMbQd0w9O0.png?auto=compress%2Cfor
After installing all the updates, the Home Assistant will display the following screen to create an account.
image_TXulahpe3D.png?auto=compress%2Cfor
Enter your name, username, and password to create your account. Ensure the password you enter is strong. Then click Create Account.
image_Auc5zXGXII.png?auto=compress%2Cfor
Then choose your location using the Detect button, select Unit System, Currency, and click Next.
If there are smart devices in your home connected to your network, Home Assistant will automatically display them for integration. You can select them and set them up or do it later. Click Finish.
image_pZe8YXaVsH.png?auto=compress%2Cfor
At this stage, the Home Assistant installation and setup is complete.
image_sklqHAtHkC.png?auto=compress%2Cfor
Wrap-Up:
Once you have Home Assistant ready, you can create rooms and add your smart home devices to the Home Assistant dashboard. You can also automate your home based on events or activities. Home Assistant offers various add-ons and integrations that you can install to enhance its features and support more smart home devices.
Link to comment
Share on other sites
Hardware components
× 1
Story
Home Assistant:
Wrap-Up:
epoxy floors toronto
To install Home Assistant on a Raspberry Pi 4, follow these steps:
  1. Download the Home Assistant OS image for Raspberry Pi 4 64-bit from this link:
  2. Install the Raspberry Pi Imager tool and open it.
  3. Select the downloaded OS image in the Imager tool.
  4. Choose the connected Micro SD card as the storage.
  5. Click "Write" and wait for the process to complete.
  6. Eject the Micro SD card and insert it into the Raspberry Pi's card slot.
  7. Connect the LAN cable to the Ethernet port of the Raspberry Pi.
  8. Power on the Raspberry Pi and wait for it to boot and update (this may take some time).
  9. Open a web browser and go to or use the IP address of your Raspberry Pi if the standard URL is not working.
  10. Follow the on-screen instructions to set up and configure Home Assistant, including creating an account, choosing location settings, and integrating smart devices.
  11. Once the setup is complete, you can customize your Home Assistant dashboard, add smart home devices, and automate your home based on your preferences.
Remember to explore the various add-ons and integrations available in Home Assistant to enhance its features and compatibility with different smart home devices.
Note: The provided instructions are a summary, and it's recommended to refer to the official documentation or guides for detailed steps and troubleshooting
Link to comment
  • 2 weeks later...
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
