Jump to content
Electronics-Lab.com Community
TS-2102B: The Beacon of Innovation for Bluetooth Beacon Tracking
1.jpg?resize=800%2C800&ssl=1
In the realm of IoT and smart environments, the TS-2102B Bluetooth beacon stands as a testament to cutting-edge technology designed to enhance tracking capabilities. With its robust Bluetooth 5.2 version and the powerful Nordic nRF52810 chipset, the TS-2102B is poised to redefine the landscape of location-based services and asset tracking.
Product Overview
The TS-2102B is a beacon that leverages the latest Bluetooth technology to provide precise Bluetooth Beacon tracking and location services. Its compact and durable ABS casing ensures that it can withstand the harshest of conditions while maintaining its functionality. The device is rated IP67, making it dustproof and waterproof, suitable for both indoor and outdoor applications.
Durability and Design
The TS-2102B is engineered to operate within a wide range of temperatures, from -20 to +60 degrees Celsius, ensuring reliable performance in various climates. Its ABS case material not only offers protection against physical damage but also contributes to the device’s sleek and modern aesthetic.
Battery and Lifespan
Equipped with a 240mAh CR2032 battery, the TS-2102B boasts an impressive battery life of up to one year, even when operating at 0dBm with a 1-second advertising interval. This longevity minimizes the need for frequent battery replacements, making it an ideal solution for long-term tracking projects.
Customization and Additional Sensors
The TS-2102B offers optional features that can be tailored to specific tracking needs. The G-Sensor allows for motion detection, which can be crucial for applications requiring movement tracking. Additionally, the temperature and humidity sensor provides environmental data that can be invaluable for monitoring conditions in sensitive environments such as server rooms, greenhouses, or cold storage facilities.
Communication and Range
The TS-2102B’s configurable transmission power, ranging from -20dBm to +4dBm, ensures that the beacon can be optimized for different environments and use cases. The advertising interval is also configurable, allowing for adjustments based on the desired frequency of signal broadcasting. With a broadcast range of 50 meters, the beacon can effectively cover large areas, making it suitable for both small and large-scale tracking applications.
Applications
The TS-2102B’s applications are vast and varied. It is ideal for retail environments, where it can help track customer flow and preferences, enhancing the shopping experience through personalized marketing and efficient navigation. In healthcare, the beacon can be used to track the location of patients and staff, ensuring safety and improving operational efficiency. Industrial settings can also benefit from the TS-2102B, where it can monitor the movement of assets and equipment, reducing downtime and improving inventory management.
Beacon Tracking
The core functionality of the TS-2102B lies in its beacon tracking capabilities. By emitting a Bluetooth signal, it allows smartphones and other devices to detect its presence and determine the proximity of the device. This can be used for indoor navigation, asset tracking, and even as a part of a larger smart home or smart city infrastructure.
Conclusion
The TS-2102B is more than just a beacon; it’s a key component in the creation of smarter, more connected environments. Its combination of advanced technology, durability, and customizable features positions it as a formidable tool in the world of Bluetooth beacon tracking. Whether used for asset management, environmental monitoring, or enhancing customer experiences, the TS-2102B is a beacon of innovation that is set to transform the way we interact with our surroundings.
Beacon%E6%8B%BC%E5%9B%BE-1.jpg?resize=75
Link to comment
Share on other sites
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
