Aaron-Tecksay Posted August 27 Report Share Posted August 27 The TS-M1052 is a high-speed BLE 5.0 Bluetooth module that supports the Bluetooth BLE 5.0 protocol. It is known for its excellent stability and ultra-low power consumption. The module features Bluetooth serial port transparent transmission capability, and users can flexibly and freely modify parameters such as serial port baud rates and Bluetooth names using the provided AT commands. Model No.: TS-M1052 Features Bluetooth Version: BLE 5.0 Frequency Band: 2.402GHz-2.480GHz ISM band TX Power: -20dBm~+10dBm Receive Sensitivity: -96dBm Air Rate: 250Kbps/1Mbps/2Mbps Antenna: PCB Onboard Advise Range: 100m Memory: 32KB RAM Size: 26.7*13*2.3mm Pin/GPIO: 26/15 Power Supply: 1.8~3.6V Operating Temperature: -40℃~+85℃ Peripheral Interface: UART/I2C/ADC Serial Transparent Transmission Rate: BLE 20KB/s Applications Smart home Location tracking Intelligent educational equipment Measurement and monitoring system Industrial sensors and controls Medical equipment monitoring and wireless control Quote Link to comment Share on other sites More sharing options...
