Jump to content
Electronics-Lab.com Community
Posted
i store my devices were manufactured in the early 90s and early 2000 and their aluminum electrolytic capacitors are original. The devices work normally, but I read that aluminum electrolytic capacitors stored for long periods without use present failures and I would like to prevent these failures due to disuse by energizing the devices here at 220v for a safe period of time to prevent failures due to disuse.
My conditions are temperature varies 32-35C in 24h, humidity 57-66% without rain.
in my case what frequency energize devices and minutes for prevent fails disuse
Posted
Electrolytic capacitors play a critical role in many devices, especially in filtering and smoothing circuits. When selecting replacements or designing new projects, voltage ratings and capacitance tolerances are key factors to consider. For a wider range of options and detailed specifications, check out Capacitors to find components suited to your application needs.
All good now?
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
