Kruti Bhinde Posted February 10 Report Posted February 10 Help me with best strategies to choose correct MOSFET for a HF inverter that I am designing. Quote
HarryA Posted February 10 Report Posted February 10 Conduction loss is larges loss in a MOSFET, it occurs when the MOSFET is in the 'on' state and current flows through its channel. It's calculated using the formula: P = Current^2 × Rds. Also switching losses occur during switch the transistor on and off. Look it this calculator and you will see how large conduction losses are compared to the other losses. https://www.dmcinfo.com/latest-thinking/blog/id/10517/mosfet-power-loss-calculator The LTspice circuit simulator has a large number of MOSFETs listed. If you post what voltages and currents you are interested in I could see what is listed there. It would benefit you to learn to use the simulator for your work. Quote
