Jump to content
Electronics-Lab.com Community
Posted
Is leakage Inductance Voltage Useful from 2 coils wound on same steel core? First is high volts in microamps with own circuit, 2nd is low volts with current in amps. The 2nd line needs over 100v. The first line doesn't short across, but passes normal volts in pulses down it's circuit and leaks across to 2nd line. The transfer volts was bench tested with neon lamps meter to be 100-200 volts added to the low 12v DC volts side. It may be called capacitive coupling superimposed volts. (looking for 150V +12v to push the 7 peak amps with 120 ohm load, low duty cycle on time.)
  • 1 month later...
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
