Forlinx Posted April 19 Report Posted April 19 Application porting on Android devices is an important part of system development. Especially on embedded platforms like RK3568, pre-installing APK, system compilation, and permission management all require specific configurations and optimizations. This guide will provide a detailed introduction on how to complete Android application porting on the RK3568 platform, including key steps such as pre-installing and uninstalling APK and obtaining Root privileges, to help developers quickly adapt and customize the Android system. Pre-installing Apps on the Android System 1. Adding an APK file: Take dogdog.apk as an example: Add an Android.mk file under the "dogdog" folder and write the relevant content for the dogdog.apk file. Add the Android. mk under the dogdog folder and write the dogdog. apk films. Android.mk writing method: LOCAL_PATH := $(call my-dir) include $(CLEAR_VARS) LOCAL_MODULE := dogdog LOCAL_SRC_FILES := dogdog.apk LOCAL_MODULE_CLASS := APPS LOCAL_MODULE_SUFFIX := .apk LOCAL_BUILT_MODULE_STEM := package.apk LOCAL_CERTIFICATE := platform LOCAL_DEX_PREOPT := false LOCAL_PRIVILEGED_MODULE := ture include $(BUILD_PREBUILT) 2. Adding an installation configuration Modify/OK3568-android11-source/device/rockchip/rk356x/ok3568_r/ok3568_r.mk Add dogdog \ Compile again to generate update. img files, which can be flahsed and pre-installed apk normally. Pre-installing Apps on the Android System 1. Delete the apk file Delete the doggo file under/OK3568-android11-source/packages/apps/ 2.Delete installation configuration Mod/OK3568-android11-source/device/rockchip/rk356x/ok3568_r/ok3568_r.mk file Delete dogdog \ 3.Delete the intermediate files generated by compilation Delete /Ok3568-android11-source/out/target/product/ok3568_r/system/priv-app/ corresponding files Compile again to generate the update. img file. Android Getting Root Privileges Location of references and test procedures: 1.The user debug version needs to be compiled. 2.Close selinux Modify the configuration according to the red prompt: Source code/device/rockchip/common/BoardConfig.mk BOARD_MKBOOTIMG_ARGS := BOARD_PREBUILT_DTBOIMAGE ?= $(TARGET_DEVICE_DIR)/dtbo.img BOARD_ROCKCHIP_VIRTUAL_AB_ENABLE ?= false BOARD_SELINUX_ENFORCING ?= false false is Close, true is Open. 3. Annotation User Group Permission Detection Comment the following two lines. Source code/system/extras/su/su.cpp int main(int argc, char** argv) { //uid_t current_uid = getuid(); //if (current_uid != AID_ROOT && current_uid != AID_SHELL) error(1, 0, "not allowed"); // Handle -h and --help. ++argv; 4. Grant root privileges to su files by default (1)Source code/system/core/libcutils/fs_config.cpp static const struct fs_path_config android_files[] = { …… // the following two files are INTENTIONALLY set-uid, but they // are NOT included on user builds. { 06755, AID_ROOT, AID_ROOT, 0, "system/xbin/procmem" }, { 06755, AID_ROOT, AID_ROOT, 0, "system/xbin/procmem" }, // the following files have enhanced capabilities and ARE included // in user builds. (2)Source code/frameworks/base/core/jni/com_android_internal_os_Zygote.cpp static void DropCapabilitiesBoundingSet(fail_fn_t fail_fn) { /* for (int i = 0; prctl(PR_CAPBSET_READ, i, 0, 0, 0) >= 0; i++) {; if (prctl(PR_CAPBSET_DROP, i, 0, 0, 0) == -1) { if (errno == EINVAL) { ALOGE("prctl(PR_CAPBSET_DROP) failed with EINVAL. Please verify " ''your kernel is compiled with file capabilities support"); } else { fail_fn(CREATE_ERROR("prctl(PR_CAPBSET_DROP, %d) failed: %s", i, strerror(errno))); } } } */ } (3)Source code/kernel/security/commoncap.c static int cap_prctl_drop(unsigned long cap) { struct cred *new; /* if (!ns_capable(current_user_ns(), CAP_SETPCAP)) return -EPERM; if (!cap_valid(cap)) return -EINVAL; */ new = prepare_creds(); if (!new) return -ENOMEM; cap_lower(new->cap_bset, cap); return commit_creds(new); } 5.Complete compilation and flashing. After compiling and flashing, you can install the RootChecker. apk to detect whether android has obtained root permission. If the prompt is "Root check pass", it indicates that root privileges have been obtained. Quote
Arish12 Posted May 10 Report Posted May 10 This guide offers a clear and practical approach to Android application porting and system customization for the RK3568 platform. It’s especially helpful for developers working with embedded systems or custom Android ROMs. The step-by-step instructions and technical depth make it accessible yet comprehensive. A valuable resource for both beginners and experienced engineers aiming to tailor Android OS behavior to specific hardware or application needs. Quote
