Jump to content
Electronics-Lab.com Community
Posted
Liquid Water Level Control Switches are critical components for maintaining operational efficiency in industrial systems. For businesses seeking precision, durability, and adaptability, the 220mm Rod Liquid Water Level Float Switch for Swimming Pool, Bilge Pump & Industrial Applications delivers unmatched performance. Engineered for harsh environments, this switch combines advanced engineering with robust materials to ensure reliable fluid management.
Why Choose the 220mm Rod Liquid Water Level Float Switch?
  1. Heavy-Duty Construction: Built with corrosion-resistant PP/Plastic/POM materials, this switch withstands extreme temperatures (-40°C to 120°C) and harsh chemicals, ideal for automotive, marine bilge systems, and industrial equipment.
  2. IP67 Waterproof Design: Guarantees uninterrupted operation in wet or submerged conditions, critical for swimming pools, humidifiers, and marine applications.
  3. Customizable Configuration: With a 220mm sensor body and adjustable wire length (default 350mm), installation flexibility is prioritized for diverse setups.
  4. High-Capacity Performance: Supports 1.5A/200VDC loads, ensuring compatibility with high-power circuits while maintaining safety via N.O/N.C contact options.
Applications Across Industries
From monitoring bilge pumps in marine vessels to automating liquid levels in industrial tanks, this Liquid Water Level Control Switch ensures precision. Its switching transducer output and 10W/50W rating load make it suitable for automotive cooling systems, wastewater management, and HVAC equipment.
Technical Specifications
- Rated Voltage: 100VDC/220VDC
- Max. Current: 1.5A
- Output: Switching Transducer
- Contact Form: N.O/N.C
For businesses prioritizing reliability and longevity, the 220mm Rod Liquid Water Level Float Switch is a strategic investment. Its adaptability to extreme conditions and ease of integration reduce downtime and maintenance costs.
Liquid Water Level Control Switches are indispensable for industrial fluid management. Explore how our 220mm Rod Float Switch can enhance your systems—visit our website to request technical specifications or consult with our engineering team. Elevate your liquid control solutions with a device engineered for precision and endurance.
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
