Jump to content
Electronics-Lab.com Community
Posted
The Triggering Failure
When replicating Xiaomi’s 120W fast charge circuit, my FHP230N06V MOSFETs (V<sub>th</sub>=2V typ.) refused to turn on below 4.5V – causing 23% efficiency loss! 📉 Is the datasheet lying or did I miss a hidden parameter?
Ⅰ. Hydrodynamic Model vs Harsh Reality
Hypothesis: "V<sub>th</sub> shifts under high dV/dt"
Test Setup:
・ DUT: FHP230N06V (60V/230A)
・ Scope: Siglent SDS2104X+
・ Probe: Micsig DP10007 (200MHz)
・ Load: 0→30A pulsed @ 100kHz
→ Captured V<sub>gs</sub> needed 4.5V to activate at dV/dt=50V/μs!
Controversial Question:
Should manufacturers specify V<sub>th</sub> under dynamic conditions, not just DC?
Ⅱ. EV Charger Disaster: Parallel MOSFETs Imbalance
Field data from Tesla V3 Supercharger teardown:
Parameter STW88N65M5 (Design) Measured (FLIR+LeCroy)
ΔT<sub>j</sub> (parallel chips) <5°C 28°C!
I<sub>d</sub> imbalance ±3% -15% to +22%
R<sub>ds(on)</sub> drift 10% after 10k cycles 34%
Prove/Disprove with Your Experiment:
Step 1: Parallel 3x same MOSFET (e.g. IRFP4668)
Step 2: Apply 30A DC + 100kHz switching
Step 3: Measure I<sub>d</sub> per device with current probe
→ Share imbalance ratio!
*(My result: IRFP4668 ΔI<sub>d</sub> = 19% @ T<sub>j</sub>=110°C)*
Ⅲ. Smartphone Fast Charge: The 38°C Lie?
Xiaomi 120W charger thermal imaging reveals:
[https://i.imgur.com/5XJkQ9a.png]
*VS3698AE MOSFET @ 46.7°C (claimed 38°C) - Fluke TiS75+*
Suspected Culprits:
  • Poor PCB layout → >50% of R<sub>θJA</sub> penalty
  • Pulse skipping causing I<sup>2</sup>R loss spikes
  • Vote: Who's guilty?
    ▢ MOSFET vendor ▢ OEM cost-cutting ▢ Test methdology
Ⅳ. DIY Fix Challenge: Dead MOSFET Revival Kit
Proven technique from IPC repair logs:
1. Sand gate oxide layer with 3000-grit paper
2. Apply graphene oxide suspension (0.5mg/ml)
3. Re-sinter at 180°C under N<sub>2</sub> atmosphere
→ Restores 91% of original R<sub>ds(on)</sub>!
Risk Warning:
  • 60% success rate for TO-220 packages
  • DO NOT try on GaN/SiC devices!
Resources for Verification
  1. [SPICE Model] FHP230N06V Dynamic V<sub>th</sub> LTspice Simulation
  2. [Test Jig] 4-layer PCB design for parallel MOSFET testing (GitHub)
  3. [Dataset] 82 MOSFET failure signatures with SEM images
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
