Raspberry Pi HAT Features K210 AI processor
XaLogic had launched a campaign on Crowdsupply for a Kendryte K210 based HAT. The K210 AI Accelerator is a compact Raspberry Pi HAT that utilizes the Kendryte K210 AI processor to enable 0.5 TOPs (Tera Operations Per Second) of processing power. Kendryte K210 is a dual-core RISC-V AI processor that was launched in 2018, and you can find it in several smart audio and computer vision solutions. The HAT also supplies a Trust-M security chip. The 65 x 30mm HAT is designed to be compatible with any 40-pin Raspberry Pi equipped with an RPi camera add-on. The HAT enables you to add AI features to your RPi based camera even if you don’t know how to train your model. The plugin module, as well as the pre-trained models, will make your camera AI-enabled in minutes with a few Python API calls. Its Kendryte K210 SoC provides 0.5-TOPS NPU performance and can run at as low as 0.3W. This is in contrast to Coral Edge TPU which clocks at 2W, and 1.5W for Intel’s Myriad X powered Neural Compute Stick 2, with both of them running at about 4 TOPS.
K210 firmware
XaLogic K210 AI Accelerator functions best with Raspberry Pi Zero and camera and enables you to make use of pre-trained models for evaluation such as object detection, face detection, age, and gender estimation,  simple voice commands, and vibration abnormally detection. You can also train your own model using a more powerful host machine. You can make use of an NVIDIA GPU, with TensorFlow. You can make use of TFLite, Caffe, and even ONNX format through the aid of conversion tools. You can make use of Visual Studio Code, which is recommended by XaLogic to modify K210 C code directly on Raspberry Pi if need be. With the aid of the Visual Studio Code for Raspberry Pi and the pivotal toolchain for the K210, you can develop all the K210 firmware on the Pi itself. The K210 AI Accelerator features an Infineon Trust-M onboard which enables you to establish a secure connection to AWS through MQTT without exposing the private key. This feature is important for your privacy when you are deploying your IoT devices in the field.
The K210 is open source, and the company says:
“Schematics, C code in the K210, and all code running on the Raspberry Pi will be open-sourced. Pre-trained models are provided in binary form. Also, sample Caffe and Tensorflow projects are available to help you create your own custom neural network.”
The company plans to manufacture the K210 AI Accelerator in China. They have also carried out a trial run of a small batch to iron out any manufacturing issues. Regarding Logistics, Crowd Supply will fulfill your pledges via their logistics partner, Mouser Electronics.  The K210 AI Accelerator HAT is over halfway toward its $3,000 goal. The module will ship in late May. Available also is a 40-pin extender for $3 which enables connection with the Raspberry Pi 3B+ or 4B to avoid an obstruction conflict with the PoE header.
K210 AI Accelerator board specifications:
  • SoC – Kendryte K210 dual-core 64-bit RISC-V processor @ 400 MHz with 8MB on-chip RAM, various low-power AI accelerators delivering up to 0.5 TOPS,
  • Host Interface – 40-pin Raspberry Pi header using:
    *SPI @ 40 MHz via Lattice iCE40 FPGA
    *I2C, UART, JTAG, GPIOs signals
  • Security
    *Infineon Trust-M cloud security chip
    *128-bit AES Accelerator and SHA256 Accelerator on Kendryte K210 SoC
  • Expansion – 8-pin unpopulated header with SPI and power signals
  • Misc – 3x LEDs,
  • Power consumption – 0.3 W
  • Dimensions – 65x30mm Raspberry Pi Zero HAT
Funding ends on Mar 11, 2021 at 03:59 PM PST (11:59 PM UTC) More information may on Crowd Supply page and the XaLogic website.
About Tope Oluyemi
I am passionate about technology especially consumer electronics and gadgets and I love to talk and write about them. At my spare time I play video games, watch movies and I love biking.
view all posts by tope
2 Comments
