Stage Line 500W amp repair project
BobK
Jan 5, 2010
7,682
It looks to me like either R108 is shorted or Q46 is shorted emitter to base.
Bob
bikemech
Oct 23, 2014
456
Bob
Q46 is reading 66.5vdc from base and emitter, would this indicate it's shorted or would it be eat to remove and test it?
BobK
Jan 5, 2010
7,682
It could be the resistor that is shorted as well.
You could try pulling one leg of the resistor and check it. If it reads good, then pull the transistor and check it.
Bob
KrisBlueNZ
Sadly passed away in 2015
Nov 28, 2011
8,393
Sorry again. Yes, I agree with Bob, unless there's an intermittent problem and those most recent two sets of readings are with the circuit in different states.
The best way to check is to remove Q46 and measure the voltage across R108, positive probe to top end. If there's no voltage (or less than 0.5V), then R108 might be faulty, or there may be an intermittent problem. If the voltage is more than 1V, then Q46 is faulty.
bikemech
Oct 23, 2014
456
Sorry kris what do you mean by top end?
KrisBlueNZ
Nov 28, 2011
8,393
Sorry, I'll be clear. Can you measure all of the marked points too.
bikemech
Oct 23, 2014
456
i can not get to the under side of the board once in the case so i soldered these pins in temporaraly for test purposes
sorry about the photo, i have no natural light at the min,
anyway here is the results i got with Q46 removed, hope this points us in the right direction,
bikemech
Oct 23, 2014
456
dont know if this helps but while testing i touched the black probe on the collector of Q46,and red on r117 and the fault led went out!!!
the one on the facia panel was still lit though!!
BobK
Jan 5, 2010
7,682
So the short is not caused by Q46. It is either R118 or something on the circuit board traces.
With all due respect to Kris, I would still suggest that you pull one leg of R118 and see if it is shorted. But first maybe inspect the other side of the PCB to make sure there is no solder bridge there after you pulled Q46.
Bob
KrisBlueNZ
Nov 28, 2011
8,393
Yes, there's something odd happeing there. It looks like R108 is shorted out, but I've never heard of a resistor going short circuit.
Can you power off the amp, and measure resistance across R108 (in circuit, probes either way round, preferably with Q46 still removed). It should measure about 1 kΩ, the marked value. If it measures short circuit (a few ohms or less), there must be a short somewhere on the PCB, possibly near the Q46 connection points.
Arouse1973
Adam
Dec 18, 2013
5,178
Hello Bikemech
How did you measure the 66.2V, just curious. With respect to what terminal.
Thanks Adam
KrisBlueNZ
Nov 28, 2011
8,393
With respect to "T4" which is the 0V rail. The amp uses split supplies which aren't supposed to be that high, but the output transistors aren't fitted yet so there's hardly any load on the power supply.
bikemech
Oct 23, 2014
456
ok set my meter to the 2000 range in the Ω section
R108 measure's 989 with the probes either way round
the amp was switched off and Q46 still removed,
R108 was still in circuit while testing.
i am going to remove the board again and look at the areas where i have changed componants, just to make sure i have not briged anything by mistake, will use the right chanel as a referance as that side seems to be ok
Arouse1973
Adam
Dec 18, 2013
5,178
Oh ok, is that quite feasible for a 500W amp to drop 20 odd volts with the output transistors connected?
Cheers
Adam
Arouse1973
Adam
Dec 18, 2013
5,178
That's really odd, you measured 0 V across R108. That means either the meter didn't measure it correctly, the resistor is short circuit or it there is no current through it.
Adam
bikemech
Oct 23, 2014
456
ok i now have something new happening!!!
have inspected the board and found a slither of copper from where the cable tidys push through the board, looked like it was shorting to or around R177,
removed this replaced Q46, (just pushed it into the pin recievers i fitted for test),
wired it up and turned it on, now i have the cooling fan on! this has never happened before, fault left is still lit tho,
also R108 measures 66.2VDC one side and 66.2VDC the other side with the negative probe to T4 0v rail
Arouse1973
Adam
Dec 18, 2013
5,178
Do you measure different voltages now from last time. What is the voltage on the top end of R108?
Adam
