Ok. The problem that I meet is that I have to measure the battery voltage while the battery is charging also or at least when its plugged and when the charger stops (about 6h). It will be charged from an ABC-1220D FST charger, rated for 20 ampers. The load will consume 24V, 25A. And the shit of having to charge separately and discharge toghether while measuring. That is the reason behind the analog components (the comparator circuit) which are then checked by the MCU. Because I dont see another way to measure the battery while its charging except to measure charger voltage until the charger stops and the battery voltage starts dropping from 14.7 to 13.7V. At 13.7 the charger will start maintain mode and the battery will not fall more.
